Wir freuen uns, Sie als Gast auf unseren Seiten begrüßen zu dürfen. Falls Sie noch kein Mitglied sind, registrieren Sie sich doch einfach kostenlos und unverbindlich, um aktiv am nuForum teilnehmen und sämtliche Funktionen nutzen zu können.
Dirac Raumkorrektur
Dirac Raumkorrektur
Beitragvon Huskykiro » Fr 21. Nov 2014, 21:51
Gruß Dieter
4000W Power by Emotiva | Sound by Nubert | Akustik by Aixfoam | Cinema by Benq
I Love Prog.-Rock
Huskykiro
Re: Dirac Raumkorrektur
Beitragvon Iceangel777 » So 23. Nov 2014, 12:59
Ich bin gespannt wann das update inkl. Mikrofon von Emotiva verschickt wird.
Iceangel777
Beitragvon Huskykiro » Fr 28. Nov 2014, 09:28
Auszug aus Handbuch XMC-1
Dirac live
Dirac Live takes the correction process a step further than other, more basic room correction systems. Because Dirac Live uses mixed-phase filters, it is able to calculate filters that not only correct the frequency response, but also compensate for errors in time response. This allows Dirac Live to correct more of the differences between how your speakers perform in your room, and how ideal speakers, in an ideal room, would sound - and enables Dirac Live to correct both frequency response and transient response. In simplest terms, because Dirac Live is not limited to correcting only problems related to frequency response, it does a better job of making your room sound more like it theoretically should.
In addition to its extensive set of manual adjustment and calibration tools, the XMC-1 includes Dirac Live for Emotiva - a powerful version of Dirac Live Room Correction optimized to run on the XMC-1 hardware platform.
Dirac Live is comprised of two modules: the Dirac Live Calibration Tool (DLCT), which takes the measurements, analyzes them, and calculates the correction filters, and the audio processing module that applies the correction filters to your music. Every XMC-1 purchase includes a
license for a single-user copy of Dirac Live LE for Emotiva, which provides all the powerful room correction capabilities of Dirac Live, but offers limited options for user customization. Users who require the ability to further customize Dirac’s operation and target curves will have the option of upgrading to Dirac Live Full for Emotiva for a small additional charge. Both Emotiva versions of Dirac Live use the same custom programmed audio processing module, which runs on the DSP hardware in the XMC-1, and is included as a module in the XMC-1 firmware.
The Dirac Live Calibration Tool is a computer program which can be installed and run on any relatively current personal computer (system requirements will be found later in this chapter). Once the Dirac Live correction filters have been transferred to your XMC-1, they are accessed
by simply selecting the Dirac Speaker Preset - which, like the two other Speaker Presets, can be selected manually from the Setup Menu or the remote control, or associated with specific inputs in the Setup Menu.
The Dirac Live LE for Emotiva package that comes with your XMC-1 includes the following:
• A single user license for the Dirac Live LE for Emotiva (DLCT) computer software.
• The Dirac Live audio processing module - which is part of the XMC-1 firmware.
• A calibrated test microphone designed specifically to work with Dirac Live for Emotiva.
• A precision USB microphone preamplifier and digitizer module - which enables you to connect the calibrated microphone directly to a USB port on your computer.
• A desktop microphone stand.
The Dirac Live Full for Emotiva upgrade package includes:
• A single user license for the Dirac Live Full for Emotiva (DLCT) computer software.
see the Dirac live Addendum for detailed instructions about how to install, configure, and use Dirac live Automatic Room Correction.
Gruß Dieter
I Love Prog.-Rock
Huskykiro
Beitragvon rockyou » Fr 28. Nov 2014, 12:13
Also muss der Einmessvorgang mit einem Computer gemacht werden und dann ein File auf die XMC 1 übertragen werden.
Ich dachte bislang, es gäbe eine vollständig integrierte Lösung...
2 x nuVero 7, 2 x AW-600, 1 x AW-1, nuControl, nuPower D, Rotel rcd 1072, DiracRCS
Kleine Drehersammlung
rockyou
Beitragvon Huskykiro » Di 9. Dez 2014, 19:13
Emotiva Dirac wird jetzt ausgeliefert
viewtopic.php?f=9&t=31408&view=unread#p787433
Gruß Dieter
I Love Prog.-Rock
Huskykiro
Beitragvon Huskykiro » Fr 12. Dez 2014, 22:59
Fragen und Antworten zu
INSTALLATION DIRAC, LIVE auf Emotiva XMC-1
https://emotiva.com/resources/XMC1_FAQ.pdf
Gruß Dieter
I Love Prog.-Rock
Huskykiro
Beitragvon Huskykiro » Mo 5. Jan 2015, 13:28
Hab schon nicht mehr dran geglaubt :roll: ,heute Weihnachtsgeschenk erhalten.
Dirac Live Kit,fehlt jetzt nur noch der Code zum Aktivieren :|
Gruß Dieter
I Love Prog.-Rock
Huskykiro
Beitragvon MGM » Mo 5. Jan 2015, 13:56
Code ist da... :mrgreen:
Packet kommt Mittwoch, laut UPS... :cry:
Bei mir kamm die UPS Benachrichtigung und die Emo Mail mit dem Code am gleichen Tag.
Check mal deinen Spamfilter!
3x NuVero 7, NuVero 3, 2x AW-17, Emotiva XMC-1, DIY Endstufe Anaview AMS1000-2600, Vu+ Duo², Oled 55eg9a7v, Oppo BDT-101CI, ATV 4K, HW55ES + 108" Draper Thor TabTension ReAct 3.0, DIY Deckensegel; PS4 Pro, Qled qe55qf6
MGM
Beitragvon Huskykiro » Mo 5. Jan 2015, 15:07
MGM hat geschrieben:Code ist da... :mrgreen:
keine Nachricht erhalten,stand heute vor der Tür.
Gruß Dieter
I Love Prog.-Rock
Huskykiro
Beitragvon Sencer » Di 6. Jan 2015, 22:11
Ich warte gebannt auf ein Update! :)
Sencer
Nächste
  • Vergleichbare Themen
    Zugriffe
    Letzter Beitrag
Zurück zu Raumakustik
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 3 Gäste
